My wifi is not working, and the Box 12 reboots
  • June 12, 2025
  • 140 keer bekeken
Hello, I was travelling for about 5 weeks and when. Icame back I noticed that the Wi-Fi isn’t working, and my KPN Box (Experia 12b) has the internet, power, and TV all green, but my Wi-Fi is turned off, it stays like that for a few minutes then everything turns off for a few seconds, then power goes red again, and the cycle repeats.
I tried manually resetting the box, resetting the box online via KPN, nothing helps. Any idea how I can fix this?
Beste antwoord door Anonymous
Hello ​@Hafez
It could be a faulty poweradapter, there is a batch which give the same symptoms after being in use for a while.
You can check the serialnumber here: https://www.kpn.com/service/internet/adaptervervangen
  • June 12, 2025
Hello ​@Hafez
  • June 12, 2025
Hello ​@Hafez
Thanks, that makes sense.
I tried the link, but like many of the services on KPN website, they’re all giving me “an error happened, try again later”.
  • June 12, 2025
That's unfortunate, you can call customer service 0800-0402 for malfunctions that should be 24/7, just say you have a malfunction (or storing).
If that doesn't work you can schedule a callback appointment, see this page: https://www.kpn.com/algemeen/english
  • June 13, 2025
Hello ​@Hafez
Thank you, I called customer service, I went to the KPN store and got a new adapter and my Wi-Fi works again!
  • June 13, 2025
Nice to hear it's working again ​@Hafez and thanks for the feedback.
