Not enough speed! I pay for 1GB connection
  • March 18, 2023
  • 420 keer bekeken
Hello,
I have a subscription of 1 GB/s with KPN fibre optics internet connection. But I have never achieved that high speed. Even now, the speed test shows an upload speed of 200 mbps and download of 190 mbps. What is wrong with the internet then?
Is the speed of 1 GB/s a myth or just a marketing gimmick? Please respond as to what is the actual internet speed achievable here. This is the screenshot of the internet test.
Beste antwoord door SMath
Try wired and connect directly to the router/gateway to check the speed. Best thing is to check it when the installation person comes. They have special equipment to test.  But funny enough i didn't get the speed on my laptop (just was checking before him for fun). I tried another laptop and it gave the speed. The nic driver of my (expensive)laptop had issues. So, i would advise to try another device as well.
WiFi itself could be the bottle neck here. It depends on whether you are using 802.11 ac or ax WAP and that itself could increase the "speed" of WiFi. I'm not saying WiFi 6 is the ultimate solution but that in my experience, even for SOHO network, it gives better experience (not just speed).
Even WiFi 6 and optimal transport i get only 300 Mbps down/up. And that's very good and i cannot find a way to make use of that goodness. That's why I said it's about experience (including the nerdiness feeling of having WiFi 6). Maybe i will Tweak it for fun to get more juice out of it (even if totally useless).
Wired i get 900+ download and upload bandwidth. Probably with a better router i can get more. I'm a heavy user (but no servers running) i can't make use of that. What i focus is on latency.
  • March 18, 2023
Could you measure the speed using the Ookla Speedtest from the Microsoft Store on a Windows PC that is connected to the network with network cable.
What is the speed you measure?
  • March 18, 2023
Here, this is the result of the speed test from Ookla.
  • March 18, 2023
How is that computer connected to the network?
What is the brand and type of that computer?
  • March 19, 2023
I have a laptop which is connected through WiFi and it's a HP probook.
  • March 19, 2023
I asked you to use a computer that is connected to the network with a network cable. This is the only correct way to measure the speed of your Internet connection.
  • March 19, 2023
Wired i get 900+ download and upload bandwidth. Probably with a better router i can get more. I'm a heavy user (but no servers running) i can't make use of that. What i focus is on latency.Â
