Old KPN Wandcontactdoos
Hello there!
I am sorry for writing it in english, but I have recently moved to the Netherlands and am still trying to learn dutch. Anyways, my apartment previously had coaxial internet conexion with Ziggo (with past tennants), but now I have switched to DSL, but my router has no internet connection.
I couldn't find an ISRA point, but I do have a "wall socket" type U1 (see attachment 01). Also, just right above it, there is an outlet with the "PTT" on it (see attachment02). I opened both outlets and it was a mess. Cables were disconnected and misconnected. I would like to know what is the proper color code. I have tried the red / blue pair seen on image 2 with no success, but I wonder if I should do something with the yellow and green cables. On another note, is there any way to test these copper wires with a multimeter or oscilloscope? What values ​​should I be getting?
I really appreciate your attention and help!
Kind regards,
Luca Serafini
Kind regards,
Luca Serafini
Hi @lucatorsera .
In general you should be able to connect the modem to red and blue wires. But there are a few variables.
Have you placed an order with KPN? The first thing the website does is checking if there is a active line on the zipcode + housenumber you supplied.
If the answer is yes you can order and most likely it will work on that red+blue pair. If not you can order a free mechanic who will measure the lines and fix the issue.
Bekijk origineelIn general you should be able to connect the modem to red and blue wires. But there are a few variables.
