Port forwarding experia v10 to connect solar panel converter. How do I do this?
  • November 12, 2021
  • 79 keer bekeken
I've to connect my solar panel inverter in internet, via the Wi-Fi network, but i do not know how to forward its ports. Can you explain?
Beste antwoord door Port forwarding
@wjb thanks! Indeed you have sent  the right link! Anyway, you were also right, I didn't need any port forwarding, but just an antenna connected to my inverter...the installer has forgotten it! 🤣
Hanna_
  • November 15, 2021
Hi @Port forwarding, welcome.
You've come to the right place! On our forum our community can help you out. Are there any specific questions you have about port forwarding?
Take a look in the following topic from @wjb. It's in Dutch but a lot of the langauge is universal.
  • November 15, 2021
@Hanna_, I think you used the wrong link. :thinking:
This topic describes how to configure port-forwardings on a V10.
It should however not be necessary to create port-forwarding for solar panels as normally the converter of solar panels is connected to the cloud of the supplier and end-users can access their converter through the portal of the supplier.
  • November 16, 2021
