Question about my connection
  • okt 11, 2025 7:44 a.m. UTC
  • 20 reacties
  • 283 keer bekeken
Hello. I signed a contract with KPN, but I don't have a point at home to connect the router. what is this? is that wandcontactdoos in the picture?
Beste antwoord door Pawel32
Hello. My internet with KPN is working fine. The phone cable was installed. I didn't have to pay any additional costs. Thank you all for your help.
20 reacties
  • okt 11, 2025 8:01 a.m. UTC
  • okt 11, 2025 8:21 a.m. UTC
Yes, that is the wall socket for electricity. You need to make an appointment for a technician
  • okt 11, 2025 8:25 a.m. UTC
Just call KPN at 0800-0402 and ask for an technician because you do not know where the connection point is.
obelisk
  • okt 11, 2025 8:29 a.m. UTC
On the left appears a 230 volt ac socket, on the right is a coaxial connector for radio, tv. In the middle is an empty box with no connection or cable. Is there a metering closet in the house where the cables for communication may enter?
huistijger
  • okt 11, 2025 8:46 a.m. UTC
Hi ​@Pawel32
The best thing to do is have a machanic come out, as ​@Ik_Combineer  and ​@TDN also said,
Before you cause any accidents.
  • okt 11, 2025 3:50 p.m. UTC
If it says here that I have kpn, does that mean I need to have a cable somewhere?
  • okt 11, 2025 3:52 p.m. UTC
Six cables come out of this socket It doesn't look like a regular socket, that's why I'm asking what it is.
  • okt 11, 2025 5:23 p.m. UTC
  • okt 11, 2025 5:24 p.m. UTC
I think someone had a router connected here before, the cables are still there
obelisk
  • okt 11, 2025 7:18 p.m. UTC
That's quite a mess in my opinion, some attention from a professional is recommended.
Hi there ​@Pawel32, I see you gave a try to connect your modem yourself! But as some of our community-members already mentioned, it indeed looks a bit messy and not how you should expect it to be.
Did you succeed in connecting your modem? If not, or if you're not sure if the connection is in a good state, then I'd also advice you to make an appointment with a technician. You can use the link below, shared by ​@TDN . Or, you can make a call-me-back appointment. Then one of my colleagues will call you back to help you with this.
Will you let us know how it worked out?
  • okt 13, 2025 4:48 p.m. UTC
Hello. Thank you all for your help. I have an appointment with a technician. I hope he'll find a way to connect the router. I don't have an ISRA, and I can't find the DSL cable. It was probably removed by the previous owner. Anyway, thanks again everyone.
Good to hear ​@Pawel32, I think that will be the best next step. When will the technician visit and will you keep us up to date on how the appointment went?
  • okt 16, 2025 1:22 p.m. UTC
I had a meeting yesterday. I don't have cable at home, I need to connect it to the house. Someone is coming to check it out on Monday. I hope there won't be any additional costs for connecting the phone line.
That should not be a problem ​@Pawel32: usually you won't pay anything if there isn't a connection point in your house and our technician visits to fix this.
  • okt 20, 2025 12:04 p.m. UTC
  • okt 20, 2025 1:45 p.m. UTC
​@Pawel32
did they found the original cable or they had to bring in a new cable from outside??
just to be curious, becouse i was the engineer at your home last week ^^
  • okt 20, 2025 1:59 p.m. UTC
they installed a new cable from the outside. thank you again for your help Have a nice day
  • okt 20, 2025 2:02 p.m. UTC
Â
