Should i be worried with a Fiber optic box close to the radiator?
  • dec 10, 2024 1:18 p.m. UTC
  • 1 reactie
  • 91 keer bekeken
Pavel  Semenov
Nieuwkomer
Hello!
I recently had fibre optics box installed. The engineer who carried out the installation said that the position of the box could be dangerous - it is too close to the radiator (see attachment). Then there was a second appointment and another engineer said everything was fine.
Should I be worried?
Hello ​@Pavel Semenov, i can understand it is a bit confusing with the conflicting information form 2 different persons.
Here at the the KPN community we have soms epxerts who can answer your question. I will mention them so they can look at the picture.
​@Ik_Combineer ​@DaveA ​ ​@DennisA78 What would you guys suggest in this case?
1 reactie
  • dec 11, 2024 2:08 p.m. UTC
