Hi there! My WiFi connection has slowed since June. I’m using KPN Experia Box ARV7519 PSN. I ran a speed test using KPN website that gave 7.9 Mbps for the download and .4 Mbps for the upload. I suspect that it might be a street repair that happened next to my house in June. They’re still carving up streets but moved to an adjacent neighborhood. I think they might have dug up the optic cable which ruined the WiFi speed. But I think my theory is presumptuous and there’s gotta be a simple explanation as to why the WiFi slowed down. I appreciate anybody’s answers on a possible problem and a potential solution. Thanks!
Hi @spacecakelover, welcome to our forum!
My first advice to increase your wifispeed is completing our online wifimanager this should have a solution for most slow wifi connections!
Can you let me know what the conclusion is?
Also could you update your profile and let me know? I'll take a look at your line from this end!
I haven’t heard from you so I'm assuming it's been fixed. If that's not the case or you have any additional questions you know where to find me!
