The Wifi light on the KPN Box 12 is not on
  • mrt 4, 2024 12:00 p.m. UTC
  • 1068 keer bekeken
Hi,
A few days ago we changed to glasvezel with KPN. The internet speed was not that great that’s why I restarted my KPN box 12. After I restarted, the wifi light is not on.
What should I do to solve this problem? Thanks.
Regards,
Astro
Hello @Yuliana.astro, let's just wait until you recieve the new KPN Box 12. If the problem comes back, we are going to help you try yo solve it.
Ratonesque
  • mrt 4, 2024 12:08 p.m. UTC
Have you tried pushing the button with the WiFi-symbol on the left-hand side of the device, @Yuliana.astro?
  • mrt 4, 2024 12:13 p.m. UTC
Yes, I did that but no effect. What else should I do? Thank you.
Ratonesque
  • mrt 4, 2024 12:26 p.m. UTC
Have you perhaps accidentally  marked this as the best answer? Because it obviously is not…
It's really strange that the WiFi isn't working as it is generated by the device itself....perhaps it's best to call 0800-0402 (for free) as they can probably detect what's not functioning on your device, @Yuliana.astro.
  • mrt 4, 2024 2:15 p.m. UTC
@Ratonesque ops, I guess I accidentally marked that. I just had 30 minutes conversation with KPN staff and she guided me step by step to restart the modem/router (which I have done more than 3 times today). Unfortunately, the problem is still here.
She is going to send me a new modem/router and we will see again after that.
Ratonesque
  • mrt 4, 2024 2:40 p.m. UTC
Yes, you probably need a new modem. I understand the WiFi worked well until you restarted the modem...obviously something went wrong here. Hopefully the new modem will provide you with a good WiFi-signal again.
  • mrt 5, 2024 3:03 p.m. UTC
