Too much connection loss
  • jan 25, 2025 8:47 p.m. UTC
  • 99 keer bekeken
modem ışıkları sık sık turuncuya dönüyor ve bağlantıyı kesiyorum cihazları 3-5 kez sıfırlıyorum ama sorun hala aynı
Hi ​@serkan caliskan, I'm sorry to hear you're facing problems with your connection 😕
Have you tried disconnecting the ONT, like ​@Ik_Combineer suggested? If this makes no difference, please contact our customer service for further assistance, so my colleague will be able to test and measure things 'live' with you on the phone!
You can easily make an appointment via our digitale assistent. Whether this is as soon as possible or at a later time that suits you best, both are possible.
  • jan 25, 2025 8:49 p.m. UTC
Please post in English or Dutch
Graag uw post in het Engels of Nederlands posten.
the modem lights often turn orange and disconnect I reset the devices 3-5 times but the problem is still the same
  • jan 26, 2025 8:48 a.m. UTC
Have you tried disconnecting the ONT (the black box from the fiber) from the power for 2 minutes? That would be my first advise. If the problemen still continue you should call KPN at 0800-0402
Maja van KPN
  • jan 28, 2025 11:51 a.m. UTC
