unstable WIFI esperia V10A
  • September 2, 2019
  • 131 keer bekeken
Federica86
Nieuwkomer
hello, I put kpn few days ago and there s something wrong with the signal.
Signal is quite good but drop unexpectedly and I have to re connect my devices every time.
It s very unstable, I work from home and I need something stable.
I just reset the box, I didn t restored it yet.
I m using only the 2.4 but seems is not working.
I red is better to change box and move to V10...
I will call kpn but in the meantime I want know if there a solution... maybe restore to factory default or do something else.
thanks
Fede
Hi Federica, welcome on our board.
Would you please fill in your profile with your address so that I can check your connection? When working from home, are you using a VPN? Does this only happen when using the VPN? Also, what devices do you have?
Forum|alt.badge.img+28
  • September 3, 2019
Federica86
Nieuwkomer
  • September 3, 2019
H Alex_p!
I Ve done! I put my address!
The issue happen not only with the vpn but also when I use my pc not for job.
It s a disaster...
Can you check for me ?
Thanks
The signal itself seems to be good, and the V10A shouldn't be the issue with this problem. I say this from experience, using one myself at home. Would it be ok for me to reset the router from here?
I would also like to send an engineer to check the connection and the connection point, if this doesn't work. The only problem is the first free one I got is on the 10th this month, in a week. So I hope the reset helps. at least temporary.
