Upload speed very slow
  • October 23, 2019
  • 11 reacties
  • 465 keer bekeken
Hello and sorry that is not in Dutch language…
I have a very low upload speed (3-4 Mbits/s) even when wired connected to the modem, while my upload is 30 Mbits/s where I live.
Do you know how it may be fixed?
Admin: moved topic to correct board
Beste antwoord door Henk2304
On DSL upload is usually about 10% of download. So an upload of 3-4 Mb/s is perfectly normal in your situation.
11 reacties
  • October 23, 2019
What is your download speed? And do you have fibre or coper (DSL) ?
  • October 23, 2019
My download speed is at this moment 27 Mbits/s. I have DSL
  • October 23, 2019
  • October 23, 2019
Ah ok. I understand then. Many thanks!
Hi @aulo1, welcome to our forums. I see Henk has answered your question already :slight_smile:  If there is anything else we can do for you, don't hesitate to ask.
  • October 26, 2019
Hi@aulo1, welcome to our forums. I see Henk has answered your question already :slight_smile:  If there is anything else we can do for you, don't hesitate to ask.
Hello Jasper, many thanks. Do you know maybe when there will be some upgrade of the network for improving the speed in Scheveningen maybe?
Hi @aulo1, I can take a look for you. To so so, I'll need you postal code and house number. Can you add those on your profile? If you post a reply after doing that, I'll know I can take a look.
  • October 26, 2019
Hi@aulo1, I can take a look for you. To so so, I'll need you postal code and house number. Can you add those on your profile? If you post a reply after doing that, I'll know I can take a look.
Many thanks. I just added the info to my profile.
Thank you @aulo1, I've checked the planning. Currently there is no update planned for your address, that might change in the future but for now your current connection is what is available.
  • October 28, 2019
Thank you@aulo1, I've checked the planning. Currently there is no update planned for your address, that might change in the future but for now your current connection is what is available.
Many thanks, Jasper.
You're welcome @aulo1 :slight_smile:
