Wegvallende verbinding: Connection has been terminated: remote station is not answering to LCP Echo requests.
  • March 25, 2022
  • 9 reacties
  • 651 keer bekeken
constant wegvallende vergbinding , is zeer irritant ivm thuis werk,  hieronder de logfile uit het modem , iemand enig idee of deze enorme berg meldingen wel ok zijn ?
logfile:
25.03.2022 11:29:47 Info SYS
Modem login was successful
25.03.2022 11:23:48 Info SYS
TR-069 connectivity to (hengelo0.cust.kpn.net) has been closed
25.03.2022 11:23:46 Info SYS
TR-069 connectivity to (hengelo0.cust.kpn.net) has been initiated
25.03.2022 11:20:25 Info SYS
25.03.2022 10:23:46 Info SYS
25.03.2022 10:23:44 Info SYS
25.03.2022 09:23:45 Info SYS
25.03.2022 09:23:43 Info SYS
25.03.2022 08:23:44 Info SYS
25.03.2022 08:23:42 Info SYS
25.03.2022 07:23:44 Info SYS
25.03.2022 07:23:42 Info SYS
25.03.2022 07:03:42 Info SYS
Modem logout was successful
25.03.2022 06:58:33 Info SYS
25.03.2022 06:52:59 Info SYS
25.03.2022 06:38:00 Info WIFI
Device <DE:8B:9E:6E:EB:64> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
25.03.2022 06:37:21 Info WIFI
A WiFi device <DE:8B:9E:6E:EB:64> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
25.03.2022 06:23:42 Info SYS
25.03.2022 06:23:40 Info SYS
25.03.2022 05:23:41 Info SYS
25.03.2022 05:23:39 Info SYS
25.03.2022 05:02:54 Info WIFI
A WiFi device <48:B0:2D:34:47:A2> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
25.03.2022 04:43:42 Info WIFI
Device <14:C1:4E:57:7D:60> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
25.03.2022 04:41:30 Info WIFI
A WiFi device <14:C1:4E:57:7D:60> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
25.03.2022 04:41:25 Info WIFI
A WiFi device <4E:9C:B9:B5:2D:BE> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
25.03.2022 04:23:40 Info SYS
25.03.2022 04:23:38 Info SYS
25.03.2022 03:23:40 Info SYS
25.03.2022 03:23:37 Info SYS
25.03.2022 02:23:38 Info SYS
25.03.2022 02:23:36 Info SYS
25.03.2022 02:21:20 Info WIFI
Device <48:B0:2D:34:47:A2> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
25.03.2022 01:23:37 Info SYS
25.03.2022 01:23:34 Info SYS
25.03.2022 00:23:37 Info SYS
25.03.2022 00:23:35 Info SYS
24.03.2022 23:23:35 Info SYS
24.03.2022 23:23:33 Info SYS
24.03.2022 22:53:21 Info SYS
24.03.2022 22:50:49 Info WIFI
24.03.2022 22:49:21 Info SYS
OWL connection status changed from ongoing to successful sync
24.03.2022 22:48:52 Info SYS
OWL connection status changed from successful sync to ongoing
24.03.2022 22:46:21 Info WIFI
Device <4E:9C:B9:B5:2D:BE> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
24.03.2022 22:45:58 Info WIFI
24.03.2022 22:44:35 Info WIFI
24.03.2022 22:43:34 Info WIFI
24.03.2022 22:43:31 Info WIFI
24.03.2022 22:42:40 Info SYS
24.03.2022 22:42:30 Info SYS
24.03.2022 22:40:58 Info SYS
24.03.2022 22:40:31 Info SYS
Incorrect Modem credentials was provided at login
24.03.2022 22:36:37 Info SYS
24.03.2022 22:36:30 Info WIFI
Device <B0:7D:64:54:68:75> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
24.03.2022 22:36:28 Info SYS
TR-069 connectivity to (hengelo0.cust.kpn.net) has failed
24.03.2022 22:36:24 Info PPPOE
PPPoE connection successfully established with user credentials.
24.03.2022 22:36:23 Info PPPOE
24.03.2022 22:35:41 Info WIFI
A WiFi device <B0:7D:64:54:68:75> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
24.03.2022 22:35:37 Info WIFI
24.03.2022 22:35:22 Info WIFI
24.03.2022 22:35:21 Info WIFI
24.03.2022 22:35:05 Info WIFI
24.03.2022 22:35:04 Error PPPOE
24.03.2022 22:35:00 Warning PPPOE
Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
24.03.2022 22:35:00 Error PPPOE
24.03.2022 22:23:34 Info SYS
24.03.2022 22:23:31 Info SYS
24.03.2022 21:32:23 Info WIFI
24.03.2022 21:31:51 Info SYS
24.03.2022 21:31:42 Info SYS
24.03.2022 21:31:37 Info PPPOE
24.03.2022 21:30:38 Info WIFI
24.03.2022 21:30:34 Info WIFI
24.03.2022 21:30:19 Info WIFI
24.03.2022 21:30:04 Error PPPOE
24.03.2022 21:30:01 Warning PPPOE
24.03.2022 21:30:00 Error PPPOE
24.03.2022 21:23:33 Info SYS
24.03.2022 21:23:30 Info SYS
24.03.2022 20:33:21 Info WIFI
24.03.2022 20:23:31 Info SYS
24.03.2022 20:23:29 Info SYS
24.03.2022 19:23:31 Info SYS
24.03.2022 19:23:28 Info SYS
24.03.2022 18:23:31 Info SYS
24.03.2022 18:23:28 Info SYS
24.03.2022 17:35:46 Info WIFI
24.03.2022 17:23:30 Info SYS
24.03.2022 17:23:27 Info SYS
24.03.2022 17:19:41 Info LETH
An Ethernet port is now connected (3/100/FULL)
24.03.2022 17:19:38 Info LETH
A device has been disconnected from an Ethernet port (3)
24.03.2022 16:32:56 Info WIFI
Device <5E:4C:B0:91:E5:D2> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
24.03.2022 16:32:23 Info WIFI
A WiFi device <5E:4C:B0:91:E5:D2> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
24.03.2022 16:32:13 Info WIFI
24.03.2022 16:32:05 Info WIFI
24.03.2022 16:23:28 Info SYS
24.03.2022 16:23:26 Info SYS
24.03.2022 15:23:27 Info SYS
24.03.2022 15:23:25 Info SYS
24.03.2022 14:23:26 Info SYS
*admin: logfile verborgen achter spoiler om het overzichtelijk te houden.
Hoi @PetervanderB, welkom op ons forum!
Ik heb de logfiles even achter spoilers gezet om het overzichtelijk te houden 😅.
In dit topic lag het aan de glasvezelmodule:
Hallo, goed dat je opnieuw contact met ons opneemt. Ik heb gelijk de verbinding doorgemeten en die ziet er momenteel goed uit. We gaan daarom samen verder op zoek naar een oplossing. Wil je allereerst de onderstaande stappen willen doorlopen?
  1. Controleer of alle kabels goed aangesloten zitten. Haal deze eventueel los om opnieuw aan te sluiten.
  2. Maak het modem en het glasvezelkastje stroomloos.
  3. Wacht twee minuten en sluit dan het glasvezelkastje weer aan.
  4. Wacht totdat het glasvezelkastje volledig opgestart is en sluit dan het modem weer aan.
  5. Geef het modem een reset.
  6. Wacht totdat het modem volledig is opgestart na de reset. Dit kan een half uur duren.
Edit 4-11: Ervaar je hierna nog steeds een wegvallende verbinding, dan is het verstandig als je telefonisch contact met ons opneemt via 0800 0402 (gratis) op het moment dat je weer wegval van de diensten ervaart. We kunnen dan naar jouw verbinding op dat moment kijken.
Als je wilt kan ik natuurlijk altijd even met je meekijken! Kun je je gegevens invullen in je profiel en hier een seintje geven als dat is gebeurd?
9 reacties
  • March 27, 2022
Niemand een idee ?  het word steeds erger
Foutmeldingen:
27.03.2022 20:51:22 Error PPPOE
27.03.2022 20:51:18 Warning PPPOE
27.03.2022 20:51:18 Error PPPOE
27.03.2022 20:14:37 Error PPPOE
27.03.2022 20:14:32 Warning PPPOE
27.03.2022 20:14:32 Error PPPOE
26.03.2022 20:36:11 Error PPPOE
26.03.2022 20:36:07 Warning PPPOE
26.03.2022 20:36:06 Error PPPOE
26.03.2022 17:19:58 Error PPPOE
Thomas van KPN
  • March 28, 2022
  • March 28, 2022
Hoi thomas,
de glasvezelmodule is bij ons recent vervangen voor een ander type ( ca 3 weken terug)  sindsdien heb ik dus deze problemen, ik heb de stappen zoals hierboven beschreven uiteraard al meerdere malen geprobeerd zonder suc6)
de module is vervangen door een nieuw type, reden onduidelijk maar op initiatief van KPN gedaan  ik vroeg nog aan de monteur waarom ze die vervangen maar die had ook geen idee .
 groet,
Peter.
  • March 29, 2022
alles gereset, probleem blijft bestaan.
Thomas van KPN
Duidelijk, dan is het toch handiger dat we even met je meekijken. Kun je je gegevens invullen in je profiel en hier een seintje geven als dat is gebeurd?
  • March 29, 2022
Profiel heb ik ingevuld.
Thomas van KPN
Bedankt voor je gegevens @PetervanderB, ik heb meteen even meegekeken en zie dat de verbinding inderdaad wel eens wegvalt maar nog niet zovaak dat ik daar meteen actie op kan ondernemen.
Ik moet je toch vragen hierover eens met ons te bellen op 0800-0402 als het probleem zich voordoet of aan het einde van de dag als de verbinding vaak weggevallen is. Mijn collega's daar kunnen dan meteen even met je meekijken naar een oplossing!
  • March 30, 2022
als je dit niet vaak noemt ?  …   ik ga wel bellen want hier ben ik niet tevreden mee.
Thomas van KPN
De verbinding valt inderdaad te vaak weg maar wij kunnen hier pas een ticket voor aanmaken als het diezelfde dag 5x gebeurd is of op het moment dat de verbinding weg is.
Om die reden is het forum niet de handigste route hiervoor.
Laat ons vooral weten wat eruit komt!
