Wegvallende wifi
  • November 14, 2019
  • 18 keer bekeken
I have the same problem that’s been thoroughly discussed here:
Experia Box V10A
Firmware v5.00.20 build190
Since day one the WiFi cuts out throughout the day on all devices even when they are right next to the router. it seems like this issue has been known about for a long time now, yet KPN is still sending out these routers to new customers?
Admin: eigen topic voor je vraag aangemaakt, afgesplitst van deze
Beste antwoord door Lisa
Hi @gerryismyname, Welcome!
If I understand your issue/problem correctly, the connected devices disconnect from the wifi while the wifi is still visable in the list of available networks? This was (and still is) indeed a known issue of the V10A experiabox. This problem can be solved by doing a hard reset. Did you already perform such a reset? Here we explain you how to do this.
Please let me know whether the reset solved your issue or not.
2 reacties
Lisa
Forum|alt.badge.img+17
  • Oud moderator
  • November 18, 2019
Lisa
  • Oud moderator
  • November 29, 2019
I haven’t seen a response from you ever since. I assume you already found an answer to your problem. If not, please let me know!
