What do I need to do to go from Ziggo to KPN?
  • feb 10, 2024 9:23 a.m. UTC
  • 441 keer bekeken
There are currently a Ziggo connection in my house, what do I need to connect KPN?
Hi @Aviv, welcome! There is probably also a KPN connection in the house. You can go to the order page of our website. There you enter your address and if we can get signal to your house, you can proceed with ordering.
If you currently have a subscription with Ziggo, be sure to select you want to use ‘overstapservice’ when ordering. This will ensure that your Ziggo contract will stop at the same time our signal goes live.
If you would like further assistance, then Noordzee's suggestion of visiting a KPN store is a good one. Via this link you can find your closest KPN Winkel.
2 reacties
  • feb 10, 2024 12:54 p.m. UTC
Hello @Aviv ,
Check this page:
https://www.kpn.com/shop/pakket-zelf-samenstellen?tv=ja&%3Ficid=quicktile1
Or visit a KPN Store in the City.
  • feb 12, 2024 2:57 p.m. UTC
