What is KPN Fiber Latency/Peering with long distance servers?
  • July 19, 2023
  • 129 keer bekeken
Hi there! I'm considering switching to KPN. I'm currently on KPN Fiber GPON Network, but before switching to KPN as ISP, I'd like to ask a favor to any other KPN/KPN user running their fiber and services:
Latency/Peering with long distance servers is the reason why I would be switching to KPN, but since I don't know anybody that has Fiber KPN I really don't know if switching will improve or make it worse.
So if anybody having fiber could run a ping test using this:
https://www.meter.net/ping-test/
Selecting the server “Argentina - Buenos Aires: EdgeUno” and share the results, I will really appreciated.
Here is the result I'm getting, with my current provider:
https://www.meter.net/ping-test/202328-91560-8a8c.html
Thanks in advance!
Beste antwoord door Anonymous
Hallo @furfix
It's just a slow connection to that server, it seems it hardly matters which provider or connection you use, I've tried 3 different connections (Ziggo (cable), Solcon (on a KPN Fiber connection) and KPN Fiber) and all are about the same:
  • July 19, 2023
Hallo @furfix
  • July 19, 2023
Thanks a lot @GeSp! Just a quick question, you ran the test connected to an eth port and over wifi, right?
  • July 19, 2023
Hi @furfix
Not over WiFi, I’ve tested from 3 different machines (with different provider connections) which are connected with a network cable.
  • July 19, 2023
Thanks a lot! Thanks a lot @GeSp . It really helped me!
