wifi box receives no power
  • October 27, 2020
  • 24 keer bekeken
Goede middag,
our wifi router is off and we cannot get it back on. We have tried changing the socket, checked the connection cables, etc.
what can be the reason for the device to not turn back on? (the wifi router is quite new, ~7 months old)
thanks in advance and kind regards,
Aiko Unterweger
Hi @AikoU, welcome! Do you mean that the Experia Box isn't working? Which Experia Box do you have? Is the problem solved already? If there is anything we can do for you, please update your forum profile with your adress and customer number.
2 reacties
Marcia van KPN
  • November 2, 2020
Thomas van KPN
We havent heard from you so I'm assuming everything got resolved. If you have any further questions don't hesitate to ask!
