WiFi connection drop
  • sep 27, 2024 7:58 a.m. UTC
  • 1 reactie
  • 38 keer bekeken
Hi,
I have a KPN modem and everything is fine about it but when connect to WIFI, connection drop regularly.
Hi @Meghdad. welcome to the community. Is it only the Wifi connection that drops, or does everything drop at that time?
If it is only the Wifi, you can see ths article for tips to improve it:
IIf it's the entire connection that drops, it's best to give us a call at 0800-0402. A colleague can check the connection together with you.
1 reactie
  • okt 1, 2024 10:15 a.m. UTC
