Wifi doesn't work with a new KPN connection
  • February 24, 2026
  • 76 keer bekeken
Hi,
I got a new KPN Internet connection and when I plugged in the modem  - LAN worked fine but there was no WI-FI displayed in the back of the router. I called the Helpdesk and they asked me to reset the modem - then for few minutes the wifi name was appearing and after that the WI-FI was not visible. Since I got the WI-FI connected I disconnected the call from helpdesk
On second time calling with Helpdesk - they mentioned that my modem is not visible to them. They said to wait for a day to check back again.
End of day, I gave my try again and still there is no WI-FI connection but LAN cable works fine. But this doesn’t solve the problem as most of my devices are connected via WI-FI.
During my first call the Helpdesk person mentioned that for new modem - the wifi name is not listed immediately. Does anyone face this kind of issue? Tomorrow I am going for work and will try later evening.
Beste antwoord door senthilr01
@Arjan van KPN - Thanks for your response. I called the helpdesk and booked a technician. The technician fixed the issue by visiting to the junction box where there was a problem.
  • February 26, 2026
Hello ​@senthilr01. Welcome to the KPN Community! With a small batch of modems, something went wrong while loading the correct SSIDs and passwords.
In principle, you can resolve this yourself relatively easily, as I understand that you do have a LAN connection. Using this LAN connection, you can log in to the modem’s web interface (http://192.168.2.254). Once logged in, go to Wi-Fi Network, where you can adjust your Wi-Fi name (SSID) and password. You can change them to the details printed on the back of the modem, or choose something different if you prefer.
If this does not work, it’s best to contact the helpdesk again. They can reset your modem in the management system, which should ensure that the SSID and password printed on the back of the modem are correctly applied. The best way to contact us now is via a callback appointment. We will call you at a time that suits you and you will immediately get an employee on the line. You can also contact us via Bluesky, X or Facebook.
We’re sorry that you’re experiencing this issue and that it isn’t plug-and-play this time. Hopefully, you’ll be able to resolve it using the steps above. If you still need assistance, please let us know.
  • February 26, 2026
  • February 27, 2026
Great to hear that the technician was able to resolve the issue. Hopefully, you won’t need us again anytime soon :)
