Wifi is not working - internet light is blinking
  • May 11, 2023
  • 103 keer bekeken
Hi,
My internet is not working for the past three days, and the internet and wifi green lights are blinking.
I have been trying to reset the modem for several times but nothing happens.
Is there anything else I can do?
Thanks.
@Herdin Welcome to our forum.
Sorry to read that your internet is not working.
If the problem still exists I would like to check what is going on.
Could you fill in your forum profile and let me know when you did?
Rutger van KPN
  • May 13, 2023
  • May 14, 2023
Yes I have already filled in the form.
Yesterday I received a new KPN box 12 and installed a new one but the problem persists.
Hope you could help me with this.
Thanks a lot.
Rutger van KPN
@Herdin I see that you received the new modem.
I made an appointment with a mechanic. Which will be there tommorrow between 08:00 and 12:00.
I also added extra data to your mobile number. So you can use that untill the problem is solved.Â
