Wrong invoice address
  • February 4, 2021
  • 10 reacties
  • 91 keer bekeken
Mind75
Deelnemer
Hi,
Last december I moved to a different house so a requested to move my Internet service too and everything was fine, but now I noted the address in the pdf invoice is still the old one, despite all data are correct in MijnKPN.
How could I fix this?
Many thanks.
Hi @Mind75, just another update from my end. It hasn't been fixed yet so I mailed my colleagues again.
They should have this fixed within a week! Thanks for your patience!
10 reacties
Thomas van KPN
Hi @Mind75! You can change this in your MijnKPN or by calling us on 0800-0402!
Mind75
Deelnemer
  • February 11, 2021
Thanks, @Thomas for the answer,
I already tried via MijnKPN, all the data are correct there but still, there’s the old address in the last invoice of February (I moved in December).
Could you tell me where exactly in MijnKPN, or the only way is calling?
Thanks
Thomas van KPN
No problem @Mind75
After you login on http://mijn.kpn.com/ you go to your mobile subscription and then click: Persoons- en betalingsgegevens
Then you'll see all of your billing data. Important to note is that you'll need to change both your regular adress (orange) and your billing adress (yellow)
Mind75
Deelnemer
  • February 11, 2021
No problem @Mind75
Thanks again, @Thomas, but I can confirm that both addresses are correct.
This is what I see (I redacted the address but I left the city).
The two addresses are the same and correct.
Maybe it could make some difference that mine is not a mobile subscription, but a home internet one?
Thanks
Thomas van KPN
@Mind75  oh right! That's completely different indeed. Sorry!
That's a whole different process which needs some actions from our end. I'll take a look if you want!
Could you update your profile (with the actual adress) and let me know?
Mind75
Deelnemer
  • February 11, 2021
Yes, please!
Profile updated.
Looking forward to hearing from you.
Thanks.
Thomas van KPN
Thanks! I've put it through to my colleagues at the backoffice. They should have this fixed in about a week. The next invoice should have the right adress!
If you have any other questions you know where to find me!
Thomas van KPN
My colleagues just mailed me that it can take up to two months for the system to catch up with the adress change after a move. This deadline is next week on 18-02. I'll double check again then and when neccesary will mail my colleagues again!
Thomas van KPN
Mind75
Deelnemer
  • March 2, 2021
Thanks for the update
