iTV KPN in browser (linux) does not work
  • mei 12, 2022 8:56 a.m. UTC
  • 289 keer bekeken
  • mei 12, 2022 2:53 p.m. UTC
That's correct. It is possible with MacOS en Windows and the browsers Safari, Google Chrome, Firefox and Microsoft Edge.
http://tv.kpn.com .
Maybe if it will work with Safari on Linux. Did you try that?  ⬇ ⬇
HansGlas
  • mei 12, 2022 3:02 p.m. UTC
The Brave browser will do the job on linux.
Hi @spectro, I don't see your message. Did the replys Peter and Hans gave help you?
  • mei 13, 2022 6:12 p.m. UTC
I am running Debian Stable with Firefox and have no problems whatsoever watching TV on linux.
https://tv.kpn.com/ works just fine here.
  • mei 13, 2022 6:46 p.m. UTC
The message was meant to be removed. But apparently it is not possible.
Although it is not the first time I have this sort of problem with KPN iTV, and it is very difficult to find the reason, because there is no “changelog” on the website… this time I was able to find a problem with my own sound driver… so after fixing that the streaming started work again.
It is just tiring to have troubles with KPN and there’s always a lot of frustration trying to find solutions… so…
So you can have an idea, last time I went without internet here, it took a few calls and 3 to 4 hours until someone would recognise that KPN had a problem…
As least this time I was able to find it here, so this post was rendered moot.
Thanks for the attention anyway.
