Are phones sold by KPN simlocked?
  • mei 14, 2023 1:35 p.m. UTC
  • 294 keer bekeken
I was wondering if a phone (iPhone 14) is sim locked ? I am going abroad for some time and want to use a foreign SIM card. Will that be possible?
Hi @Lijana, Apple devides their territories into the Americas, EMEA, and the Asia Pacific. EMEA stands for Europe, Middle East, and Africa. If you buy a phone in the EMEA region, you can't use a sim card from a provider that's from another region. If this is your intent, you can contact Apple, to ask if they can remove the EMEA lock!
2 reacties
RBxx
  • mei 14, 2023 2:04 p.m. UTC
Yes, you can. KPN stopped simlocking at least 10 years ago, so your iPhone is not simlocked.
However, depending on the country/region you visit, your phone might be blocked by a region lock. With a region lock, a manufacturer of mobile telephones ensures that their devices are only used in the market for which they are intended. You'll need to check that with Apple.
Maja van KPN
  • mei 15, 2023 7:44 p.m. UTC
