Cannot call anyone when outside of Netherlands
  • jul 24, 2020 11:08 p.m. UTC
  • 105 keer bekeken
hi support,
I have a postpaid connection and cannot call anyone when outside of netherlands.
Can you plz help me?
Thanks,
Rakshit
Beste antwoord door Susan_
Thanks for your data @Rbj. I looked for you and I saw a blockade on outgoing calls from abroad. I have now removed this blockade. When you restart the device you should be able to call again. Would you like to test this for me and share the result with us?
  • jul 25, 2020 5:41 a.m. UTC
I am able to receive the call and data works fine.
Thomas van KPN
Hello @Rbj, welcome to our forum!
Could you add your address and the last 3 digits of your IBAN to your profile? You can add this to the field “persoonlijke opmerkingen”
In which country are you experiencing this issue and have you tried rebooting your phone?
  • jul 25, 2020 6:03 p.m. UTC
Hi Thomas,
Thanks for your reply and have added the details.
Thanks,
Rakshit
Susan_
  • jul 26, 2020 6:40 a.m. UTC
  • jul 27, 2020 9:31 a.m. UTC
Thanks a lot and i am now able to call.
Susan_
  • jul 30, 2020 6:43 a.m. UTC
@Rbj, great to hear! No problem, you're welcome :blush:
