E-sim not working on iPhone 14 Plus
  • aug. 15, 2024 3:00 p.m. UTC
  • 1 reactie
  • 48 keer bekeken
Travel E Sim not supported on iphone 14 plus. Phone is updated. I need assitance
Beste antwoord door Marijn25
Hmm, Thats weird! it should work with the iPhone 14 Plus. Have you tried restarting the device and then try it again? You can also try to reset the network settings and then try again activating the E-Sim through the “Mijn KPN” app. If you tried these options I gave you and it still doesn't work, then I suggest you going to a KPN Store, an employee there can check what is going on with your device and why it is not activating.
1 reactie
Marijn25
Topper
  • aug. 15, 2024 7:26 p.m. UTC
