High ping spikes with KPN Unlimited and online gaming
  • December 18, 2023
  • 108 keer bekeken
Hi,
On Sunday I bought SIM card with unlimited internet and now I have constant internet spikes, every 30~ seconds it randomly spikes from 30 to even 3k ping. Also KPN for some reason is blocking connection to riot games servers. I would love if you fix it so I dont have to cancel my contract.
We don't specifically support these services on a mobile connection due to the nature of the signal. Maybe the coverage is not adequate enough but I don't have a specific reason I can offer you as a solution.
  • December 19, 2023
Well it works fine with lebara somehow and Ive just changed because they dont have unlimited internet, I think there is a way to fix it. Because I find it hard to believe that suddenly yours doesnt work well when lebara signal comes out of the same transmitters. And the blockage of riot servers is still your choice.
  • December 19, 2023
Which apn are you using? Try to use apn portalmmm.nl instead of apn internet.
