I can’t change my subscription to more Gb's
  • October 9, 2022
  • 1 reactie
  • 74 keer bekeken
I want to change my subscription from 20€(10gb 150 min) which I made in office of KPN to 25€ (50gb) which I found in app. For some reason consultant at office didn’t tell me about the last plan. But when I’m trying to change plan I see this  U kunt uw abonnement niet wijzigen, omdat een wijziging naar ander product niet is toegestaan of omdat er een wijzigingsverzoek in behandeling is. Can you help me with it please
1 reactie
Denise van KPN
Hello @Mihail Marcenco, welcome.
How long have you had your subscription for? If it has been less than a month, the error you get is correct. You can only change your subscription once a month. So if it has been less than a month since your subscription started, you're going to have to wait a little longer. After the first month, you can change your subscription to a higher plan.
