Is KPN300 really unlimited data?
  • mei 23, 2024 6:03 p.m. UTC
  • 1 reactie
  • 173 keer bekeken
mikoongg
Nieuwkomer
is it really unlimited data or just 50GB for a month???
Beste antwoord door RBxx
Hi @mikoongg
With Unlimited300 you can use as much data in the Netherlands as you need per day. Do you use more than 20GB in 1 day? Then you can activate an extra 2GB (for free) as often as you want via SMS or MijnKPN to use the internet at full speed again. This way you will never run out of data.
Depending on your type of Unlimited subscription, you can roam up to a maximum of 75GB in the EU. With Unlimited50 you have 40GB in the EU. With Unlimited300 you have 50GB per month in the EU and with SuperUnlimited you have up to 75GB in the EU.
1 reactie
RBxx
  • mei 23, 2024 6:13 p.m. UTC
Hi @mikoongg
Â
