MB's delen werkt niet
  • jan 19, 2020 5:07 p.m. UTC
  • 66 keer bekeken
I have the same problem. It is bad for me because I just moved to The Netherlands and do not speak or read Dutch. It is difficult to use the app because it is not available in english and I keep getting that same response when trying to share MBs with my family members. All three phone numbers are listed in app and online though.
*Admin: reactie afgesplitst, eigen topic aangemaakt.
Thank you! I see that you weren't registred for the ‘Hussel privileges’ such as MB's delen. I registered your Internet subscription and also all of the 06-numbers, so it should work in a couple of days!
Marcia van KPN
Hi @TravelingIronman, welcome! If, in the app, you go straight to ‘MB's delen’ , pick the amount and recipient and press ‘verzenden'. That doesn't work? Could you update your forum profile with your zipcode, house number and 06-number? If you're not sure where to put it, put it in ‘persoonlijke opmerkingen'. Only you and KPN can see it. I will look into it!
If I click on MBs delen all I get is the message the original poster mentioned no option to pick an amount or recipient. I have updated my forum profile now.
Marcia van KPN
  • jan 21, 2020 1:26 p.m. UTC
Thank you! I will reply here again if it doesn't work in a few days.
