Provider in Japan
  • June 16, 2020
  • 243 keer bekeken
su1sin
Nieuwkomer
I'm planning to use your global sim card in Japan with roaming service. Could you tell me which local provider will be selected? ex. Softbank/Au/Docomo etc.
Hi @su1sin, welcome to our forum! When you're in Japan your phone will choose the strongest network. Which one that is can differ per location. If you want to use a specific provider you can set your phone to that provider, so it'll only connect to that. A few years ago I was in Japan too, in the 3 weeks I was there I've seen several local providers.
It's also possible to get a local Japanese simcard. If I recall correctly there is a shop on Narita that provides those, very close to the JR (Japan Rail) ticket office. If you have one of those you'll be connected to the network you choose.
2 reacties
su1sin
Nieuwkomer
  • June 26, 2020
Hi Jasper, thanks to you, my question has been resolved! I highly appreciate your great support:)
