Using iPhone 12 (Subscription) with sim from another operator
  • August 21, 2021
  • 109 keer bekeken
Hello,
Is it possible to use a sim from another operator (eg. T-Mobile) on a iPhone 12 under contract (24 months) with KPN?
Thank you.
UPDATE: According to this topic:
I should be able to use another operator SIM card on a newly bought iPhone 12 with KPN subscription. Can anyone confirm this? Thanks
Beste antwoord door RBxx
Yes @Walstice
Mobile phones are not sim-locked nowadays, so it will work with a simcard from any provider.
Edit: Keep in mind that your obligations under the KPN subscription will continue .
2 reacties
RBxx
  • August 21, 2021
Yes @Walstice
  • August 21, 2021
Great, thanks you so much!
