What APN setting to use for hotspot? on an iPhone?
  • feb 13, 2025 11:32 a.m. UTC
  • 1 reactie
  • 221 keer bekeken
Hi,
What would you recommend to use in iPhone Network’s APN settings for the Hotspot?
It seems like I cannot access Netflix via Hotspot (I changed mobile data APN to portalmmm.nl and it doesn’t work with hotspot using internet or portalmmm.nl).
Any thoughts, please? 😔
1 reactie
Jan van KPN
  • feb 17, 2025 2:47 p.m. UTC
Hello ​@Simona S , thanks for your message and welcome to our Community :)
That's strange because using 'internet' for APN should be the right way. You can also check this in this online manual. Netflix is the only thing you're encoutering problems with?
