Installation is stuck on 'preparing your connection'
  • jan 30, 2026 4:17 p.m. UTC
  • 1 reactie
  • 47 keer bekeken
I have followed all the steps to connect my internet but I continue to get stuck on the “preparing your connection” screen.
the lights on the fiber box are working fine
the right cables are connected to the modem
Even the light is green and not flashing
How do I solve this?
Hi ​@Eliana_, welcome to the community. I see you've connected the modem via a wallconnector. Did you also try to connect the modem directly on the fiber box? A direct connection might help in this situation.
If you have tried that and didn't get further, it's best to make a callback appointment via our site. That way a colleague can check the connection together with you, and decide what the next steps should be.
1 reactie
  • feb 2, 2026 2:05 p.m. UTC
