KPN Box 12 reboots randomly
  • sep 28, 2024 9:18 p.m. UTC
  • 184 keer bekeken
KPN Box 12 randomly reboots every ~15 minutes. It started about 3 weeks ago. No changes to wiring has been made. There were zero problems many months before. Should I request a replacement Box?
Beste antwoord door Noordzee
Ok @edrokov
Call with 0800-0402 for help.
  • sep 29, 2024 6:16 a.m. UTC
@edrokov
Uw  vraag in het Nederlands graag.
  • sep 29, 2024 6:17 a.m. UTC
Hallo @edrokov ,
Do a reset:
  • okt 2, 2024 10:11 a.m. UTC
Hallo @edrokov ,
Do a reset:
Thank you for the suggestion but it didn’t help.
Anyone knows how to order a new KPN Box 12 (or whatever modern version)?
  • okt 2, 2024 10:22 a.m. UTC
Ok @edrokov
  • okt 2, 2024 10:51 a.m. UTC
Ok @edrokov
Thanks, they have concluded there is a hardware problem with optical modem, and somebody would come tomorrow for a check/replacement.
  • okt 4, 2024 4:20 p.m. UTC
Ok, the final note: the technician has explained one specific KPN Box 12 batch is known for having faulty power adaptors, and my Box is from that batch. He has replaced the Box and power adaptor and everything works as it should for more than a day now.
