KPN VDSL2 [Bonded] Dialer Cisco IOS 15.8 en hoger - 8XX en 11XX
  • nov 26, 2023 3:36 a.m. UTC
  • 0 reacties
  • 154 keer bekeken
Cisco 89X 15.8
VDSL (Bonded) Dialer KPN Cisco IOS
Hopelijk heeft iemand hier wat aan, de Dialer is ook voor PPPoE voor FTTH (Glasfiber)
cq:
ipv Ethernet0 gebruik je GigabitEthernet 8 of 9 (800 serie) of GigabitEthernet 0/0/0 of 0/0/1 (1100 serie).
Hier geen LAN config en FW…. Ik ga er vanuit dat als je Cisco IOS router gebruikt, je dat ondertussen al weet. Mocht iemand behoefte hebben, laat het maar weten!
Ciao
S
controller VDSL 0
 operating mode vdsl2
 ! firmware filename flash:VA_A_39h_B_38h3_24h_j.bin WERKT OOK MET EMBEDDED FW
 ! line-mode bonding ALLEEN 897VAB
 sync mode itu
 sra
interface Ethernet0
 mtu 1512
 no ip address
interface Ethernet0.6
 encapsulation dot1Q 6
 pppoe enable group global
 pppoe-client dial-pool-number 1
 pppoe-client ppp-max-payload 1500
interface Dialer1
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip virtual-reassembly in
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 dialer idle-timeout 0
 dialer-group 1
 no cdp enable
 ipv6 address 2A02:A4XXX:XXXX:0:b19:ba11:c001:b00b/64
 ipv6 enable
 ipv6 nd ra interval 30
 ipv6 verify unicast reverse-path
 ipv6 dhcp client pd hint 2A02:AXXX:XXXX::/48
 ipv6 dhcp client pd kpn-dsl-prefix rapid-commit
 ipv6 mld query-interval 60
 ipv6 virtual-reassembly in
 ppp authentication pap callin
 ppp pap sent-username kpn password 7 07043142
 ppp ipcp dns request
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipv6 permit
ip route 0.0.0.0 0.0.0.0 Dialer1
ipv6 route ::/0 Dialer1
ipv6 ioam timestamp
c897vam#ping 1.1.1.1
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/9/12 ms
c897vam#ping ipv6.google.com
Sending 5, 100-byte ICMP Echos to 2A00:1450:400E:810::200E, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/8/8 ms
c897vam#
