Return of hardware didn’t work
  • okt 25, 2024 3:21 p.m. UTC
  • 118 keer bekeken
Hello there, I already contacted you about my question and send a parcel to the address you gave me but it returned and said the address is valid. I even needed to pay extra for the return…
Any ideas what I should do now?
Also I don’t have the parcel you send to me as I already moved out of my flat.
kind regards
Anna
Admin: removed private information
Beste antwoord door RBxx
Hi @A_fdm
As I told you earlier in this topic the correct address for returning KPN equipment is
KPN
Antwoordnummer 10119
2400VB Alphen aan den Rijn
The Netherlands / Die Niederlande
Make clear to the German postal service that this is an address in the Netherlands.
DaveA
  • okt 25, 2024 5:28 p.m. UTC
Hi @A_fdm, returns can only be made via PostNL or a KPN store, not DHL. This is always free of charge. If you write the information below on the box and give it to them, you will be fine.
KPN Antwoordnummer 10119
RBxx
  • okt 25, 2024 5:52 p.m. UTC
Hi @A_fdm
KPN
  • okt 25, 2024 5:53 p.m. UTC
@A_fdm The address is invalid because the postcode is missing
@DaveA A international parcel shipment is not free of charge, it does not matter with DHL or POSTNL or whatever. You need to pay the cost for schipping from abroad to Netherlands
We did, you just can not see the whole address as they put a return sticker on top of it
  • okt 25, 2024 6:07 p.m. UTC
@A_fdm You can try this adres
KPN Klantenservice
Postbus 235
2400 AE Alphen aan den Rijn
