KPN Veilig blijft vragen op opnieuw te starten
  • jul 31, 2021 10:11 p.m. UTC
  • 318 keer bekeken
AL geruime tijd vraagt KPN veilig om de paar minuten om opnieuw te starten.
In het begin deed ik dat maar om dit elke 10 minuten te doen is te gek.
Als ik in de log kijk zie ik :
2021-07-31 23:26:09.475 [1230.177c]  I: ***  LOGGING STARTED  *** (UTC+2:00, session: 0x0)
2021-07-31 23:26:45.349 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:26:45.364 [1230.177c]  I: Update check failed, error=210 (unable to resolve host)
2021-07-31 23:26:50.395 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:26:50.395 [1230.177c]  I: Update check failed, error=210 (unable to resolve host)
2021-07-31 23:26:59.414 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:26:59.414 [1230.177c]  I: Update check failed, error=210 (unable to resolve host)
2021-07-31 23:27:09.439 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:27:09.439 [1230.177c]  I: Update check failed, error=210 (unable to resolve host)
2021-07-31 23:27:34.464 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:35:29.865 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:35:42.294 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:39:31.169 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:24.476 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:25.835 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:27.242 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:30.490 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:31.389 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:32.248 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:32.920 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:33.670 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:42:34.327 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
2021-07-31 23:50:27.473 [1230.177c]  I: Checking for updates from guts2.sp.f-secure.com
Beste antwoord door Noordzee
Hallo @Verst01 ,
Ik zou eerst KPN Veilig eens helemaal verwijderen. En daarna weer terug erop zetten.
Hoe verwijder ik KPN Veilig van mijn laptop of PC?
  1. Klik links onder op het [Windows] icoon
  2. Navigeer naar KPN Veilig
  3. Klik op [Installatie ongedaan maken]
  4. Klik op [KPN Veilig]
  5. Klik op [Verwijderen/wijzigen]
  6. Selecteer [Alle applicaties verwijderen]
  7. Klik op [Volgende] KPN Veilig wordt van je PC verwijderd
  8. Klik op [Sluiten] KPN Veilig is van de PC verwijderd
  • aug 1, 2021 6:23 a.m. UTC
Hallo @Verst01 ,
Hoi @Verst01, welkom op het forum. Elke 10 minuten opnieuw opstarten is wel heel veel inderdaad, dat is niet de bedoeling! Ik ben net als Noordzee benieuwd hoe het gaat als je KPN Veilig verwijderd en daarna opnieuw installeert. Blijft deze melding dan ook komen?
We hebben geen reactie meer van je gezien @Verst01, ik hoop dat dat betekent dat de tip van Noordzee de oplossing was. Als dat niet zo was horen we het graag van je.
  • aug 6, 2021 5:40 p.m. UTC
Noordzee,
Bedankt, werkt weer
