How can I activate prepaid outside the Netherlands
  • April 8, 2025
  • 103 keer bekeken
How can i activate the SIM Card outside from the Netherlands?
Beste antwoord door RBxx
Hi ​@Donavan
You can only activate this yourself when you are in the Netherlands, connected to the KPN network.
However, a KPN employee can do this for you remotely.
Place your 06-number and SIM card number (ICCID) in your community profile . Use the field "Persoonlijke opmerkingen" and save your input by pressing "Sla wijzigingen op".
Report here when this is done, then I'll bring your question to the attention of the KPN moderators.
RBxx
  • April 8, 2025
Hi ​@Donavan
  • April 8, 2025
It’s done.
Thank you
Hi ​@Donavan, welcome! I've activated the sim for you. It should work immediately. If not, restart your phone :)
Thanks, RBxx!
  • April 8, 2025
Thanks for your Support!
Â
