How to topup from roaming country
  • August 23, 2020
  • 135 keer bekeken
zawwinn
Nieuwkomer
Hello I have a KPN prepaid SiM and 10Euro topup pin code. Instructions say text pin to 1266. But it doesn't work. I have zero balance.
Please give me a advice.
Is there are USSD code for topup?
Best Regards
Beste antwoord door Misja20
thank you for your reply  but couldn't sent to 1266. Message sent failed. May be no balance in my account.
Lets try another option. Call the free number 1244 and choose option 9. Then enter the top up code and close with #
That should work.
Forum|alt.badge.img+7
  • August 24, 2020
Hi you can top up by text message.
Send the following sms: *top up code* and then the text OPWAARDEREN to 1266
zawwinn
Nieuwkomer
  • August 24, 2020
  • August 24, 2020
That should work.
zawwinn
Nieuwkomer
  • August 24, 2020
Many thanks for your information it work.
Best Regards
Zaw Winn Maung
