Pre-paid KPN does not allow me to call abroad
  • apr 17, 2021 4:35 p.m. UTC
  • 106 keer bekeken
What is the best to contact KPN way to contact KPN to solve an issue with my pre-paid card?
Hi @Hendrik147, welcome! The quickest way is to call us at 0800-0402 (free). Alternatively we can assist your here. In that case, fill in your forum profile with the telephone and sim card numbers (both can go in the ‘klantnummer mobiel’ field) and reply here when you've done so. We'll get back to you then tomorrow morning.
  • apr 17, 2021 7:58 p.m. UTC
  • apr 18, 2021 8:39 a.m. UTC
Thank you, @Erik_ .
I have entered the numbers in my profile.
Maja van KPN
  • apr 18, 2021 9:39 a.m. UTC
Thanks @Hendrik147!
When I check your balance, I see you have a call credit of €0,00, which explains why you're not able to make any calls. If you top up your balance, you should be able to use your card again :slight_smile:
  • apr 18, 2021 12:19 p.m. UTC
Thanks, @Maja_
