Sticky
  • sep. 8, 2018 2:29 p.m. UTC
  • dec. 19, 2025 1:17 p.m. UTC
  • 8986 reacties
  • 668213 keer bekeken
8986 reacties
  • okt. 13, 2024 1:37 p.m. UTC
Ik heb 3 switches hangen, ik denk dat jij uit het screenshot wel kan opmaken hoe de bekabeling is:
Kelder:
Meterkast:
Woonkamer:
  • okt. 13, 2024 6:56 p.m. UTC
Ook dat ziet er allemaal goed uit.
  • okt. 31, 2024 10:50 a.m. UTC
Misschien een suffe vraag maarreee..
Moet ik hier mijn eigen gegevens invullen?
mtu 1500
                name-server auto
                password ppp
                user-id XX-XX-XX-XX-XX-XX@internet
Groet Michel
  • okt. 31, 2024 11:30 a.m. UTC
Je mag willekeurige waarden gebruiken maar als je de installatieprocedure volgt dan zal die XX-XX-XX-XX-XX-XX automatisch vervangen gaan worden door het MAC adres van jouw EdgeRouter.
  • nov. 2, 2024 8:53 a.m. UTC
Make sure your own router is configured to use pppoe on vlan 6. The user name and password can be anything.
Hi again,I was able to set up the deco XE75, working fine, however as soon as I turn on the ipv6 it looks like something wrong, I’m getting new ipv6 addresses every 5 seconds or I don’t get it all.
  • nov. 2, 2024 8:55 a.m. UTC
  • nov. 2, 2024 9:23 a.m. UTC
How are the IPv6 settings for the LAN side of the router?
  • nov. 2, 2024 10:12 a.m. UTC
  • nov. 2, 2024 10:17 a.m. UTC
Again, how are the IPv6 settings for the LAN​​​​ side of the router?
  • nov. 2, 2024 10:39 a.m. UTC
Could you please more specific? What options should I look for?
  • nov. 2, 2024 10:50 a.m. UTC
It could be that the "Assigned Type" is a LAN setting but then there would be a typo as then it should not be "Assigned Type" but "Assign Type".
What are the options you have for "Assigned Type"?
  • nov. 2, 2024 10:57 a.m. UTC
These are we looking?
  • nov. 2, 2024 11:01 a.m. UTC
Use SLAAC+RDNSS.
  • nov. 2, 2024 11:31 a.m. UTC
It’s working but I’m getting new ipv6 adress every 5-10 seconds, and because of that there is a delay in loading webpages etc. Should I try restart the fiber box?
  • nov. 2, 2024 11:56 a.m. UTC
How do you check that your device gets a new IPv6 Address every 5-10 seconds?
I assume you are aware of the fact that it is normal for every device to have one fixed IPv6 address (based on the MAC address) and multiple temporary IPv6 addresses used for browsing the Internet.
This is on purpose in order to improve your privacy on the Internet.
  • nov. 2, 2024 3:49 p.m. UTC
With this setup it’s working perfectly! Can be true? 😊
  • nov. 2, 2024 4:01 p.m. UTC
That can be true.
  • nov. 3, 2024 10:25 p.m. UTC
Hai,
Is de Lijst met (modem)routers die succesvol op een KPN aansluiting i.c.m. IPTV in gebruik genomen zijn zoals deze staat in post 1 van dit draadje nog steeds up to date, of zijn er alweer nieuwe routers bijgekomen die goed overweg kunnen met KPN iptv & internet?
Groeten,
Jelle
  • nov. 3, 2024 10:29 p.m. UTC
Ik heb nog geen andere routers gezien waarvan met 100% zekerheid gezegd kan worden dat deze geschikt zijn.
  • nov. 3, 2024 10:32 p.m. UTC
Dank voor het snelle antwoord!
  • nov. 3, 2024 10:36 p.m. UTC
Wellicht een domme vraag, maar: stel ik installeer op de tv de KPN app om zo tv te kijken in plaats van via het kastje; is het systeem dan nog steeds zo gevoelig mbt welke router ik gebruik etc, of maakt dat dan niet meer uit?
  • nov. 3, 2024 10:40 p.m. UTC
Nee, de app gebruikt immers geen multicast. Ik zou het echter zeer onverstandig vinden om een router te kiezen die niet geschikt is voor Multicast televisie van KPN immers je gooit een behoorlijk deel van de beeldkwaliteit daarmee in de vuilnisbak en dat is mijns inziens doodzonde.
Forum|alt.badge.img+4
  • nov. 6, 2024 7:13 a.m. UTC
Het ziet er naar uit dat Unifi Gateways firmware 4.1.2 (UXG Lite/Max/Pro/Enterprise) [early access] niet werkt met udm-iptv. Deze combinatie zorgt voor problemen op mijn UXG Lite, het CPU verbruik blijft lange periode's op 100%. Dit heeft als gevolg dat de internet verbinding onstabiel is, regelmatig verbroken wordt en dat IPTV stottert. Een downgrade naar firmware 4.0.20 lost het probleem op. Hebben meer gebruikers deze problemen ondervonden met firmware 4.1.2?
  • nov. 6, 2024 7:29 a.m. UTC
@dmutsaers, Ik zie dat je ook melding hebt gemaakt op de github van Fabian. Ik hoop dat er snel reactie zal komen en dat er een oplossing zal zijn voordat firmware versie 4.1.2 live gaat.
Heb je kunnen zien welk proces die 100% belasting van de CPU veroorzaakt?
  • nov. 6, 2024 9:07 a.m. UTC
Hoi @wjb ,
Nee dat heb ik nog niet gecontroleerd. Dat zou ik met top (of htop) kunnen doen? Ubiquiti komt niet verder dan “Remove all custom components".
High CPU usage | Ubiquiti Community
