All devices lose internet connection when connecting work laptop to tailscale VPN with KPN Box 12
  • jan. 16, 2025 2:43 p.m. UTC
  • 20 reacties
  • 343 keer bekeken
Previous post:
I am creating a new one with better understanding of the issue
Issue: Sometimes, when I open work laptop in the morning and it starts connecting to tailscale vpn, internet stops working for all my devices
My current best guess is that this is an issue of KPN Box 12. Maybe because of old software (`SGEJ1000060E`)
What I tried:
  • Reconnecting and resetting KPN Box 12
  • Reconnecting fiber box
  • Changing ethernet cables between fiber box and KPN Box 12
  • Using ethernet cable and wifi for connection
I know at least of 2 coworkers who have the same issue with the same symptoms
I have this issue since I moved and connected to KPN (3 months). It happens sometimes with varying intervals: once a week or every day
I tried a different router and it worked. Then I switched back to KPN Box 12 and it worked for 8 days
I lived in Rotterdam before with solutio365 internet (Maybe backed by KPN) and didn’t have these issues
It happened today and I tried to capture it with more details. I will post a separate message about it
Beste antwoord door krock21
Around a month ago, after some failed updates, I received a software update for my KPN Box 12.
Software version SGEJ1000060E changed to V12.C.24.05.08
Seems like it helped. I had no issues since then
20 reacties
  • jan. 16, 2025 2:45 p.m. UTC
​I got the issue today. I will try to describe everything
I switched to the simplest setup 8 days ago: Kpn Box 12 connected to fiber box. All my devices connect to Kpn Box 12 wifi
I have normal dual-band wifi, and I have extra wifi enabled with separate SSID for 2GHz and 5GHz
My laptops use 5GHz one
8 days it worked well, with no issues
Today I opened my working laptop that started connecting to corporate tailscale vpn, and internet stopped working for all my devices. It didn't work for 5-10 minutes and then started working
I started `ping 192.186.2.254` and `ping 8.8.8.8` on both personal and working laptop soon after internet dropped. I started connecting my 2nd laptop with ethernet cable, but wasn't able to do it on time. I suspect it would have the same issues, I have some screenshots with pings that prove it
In the kpn box 12 logs I see that internet dropped without any logs, then my devices disconnected from wifi (cause no internet), then `Connection has been terminated: remote station is not answering to LCP Echo requests.` and `Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)` and `PPPoE connection successfully established with user credentials.` that fixed the internet. You see my attempts to connect ethernet cable too
pings from working laptop
pings from personal computer:
Kpn Box 12 logs during the event
Now every time I connect tailscale, I see internet interruption.
It wasn't like this last 7 days
  • jan. 16, 2025 8:53 p.m. UTC
Happened today again when I turned on my computer. Again on all devices.
Then smaller downtime happened when I turned on tailscale
Turning on the computer (maybe tailscale on work laptop reconnected too, not sure)
Laptop, connected through ethernet
Computer, connected through wifi
And when turning on tailscale on working laptop
Computer, wifi
  • jan. 17, 2025 10:27 a.m. UTC
I did reset on my kpn box 12 now and will stop using extra wifi (that gives me separate 2ghz and 5ghz SSIDs)
It works well now, will see in 8 days
  • jan. 17, 2025 10:46 a.m. UTC
I got a confirmation from 3 coworkers that they have the same kpn box 12, same software version `SGEJ1000060E` and the same problem
I suspect the problem was not in extra wifi feature
Denise van KPN
  • jan. 20, 2025 11:10 a.m. UTC
We don't recognise the issues you're describing, ​@krock21. What might help, though, is adjusting the MTU size to 1280. This is something you'd have to adjust in the VPN settings. I hope this works for you.
  • jan. 20, 2025 11:32 a.m. UTC
Thanks
Will try it next time I have issues
  • jan. 20, 2025 12:51 p.m. UTC
Tailscale configuration is managed by my employer
They said it is already configured to 1280 and it doesn't look like an MTU problem
Do you have any other ideas/suggestions?
Denise van KPN
  • jan. 21, 2025 10:39 a.m. UTC
I am afraid I don't have another suggestion. We do not block the usage of VPN. The common factor seems to be your work VPN. So it might be something in their configuration. I'd suggest you take this up with the IT servicedesk at work. Hopefully they can help.
  • jan. 23, 2025 1:14 p.m. UTC
My kpn box should have been updated this night(I received an email yesterday), but seems like something went wrong, because my software version is still `SGEJ1000060E` and I saw a couple of `Remote station is not answering to LCP Echo requests` in the modem logs at night
Today I was able to capture small outage (3 minutes) when I turned on tailscale. I downloaded PingPlotter for it, it should do traceroute and plot pings to every hop
I don’t see any log messages in kpn box 12 at that time
I did it on 3 devices:
Working laptop, connected through wifi and connected to tailscale:
Personal computer, connected through wifi:
Personal laptop, connected through a cable:
Denise van KPN
  • jan. 23, 2025 5:30 p.m. UTC
It looks like the update failed then, ​@krock21. If this keeps happening, my advise would be to reset the modem. This increases the chance we'll be able to push the update.
  • jan. 23, 2025 6:22 p.m. UTC
I did modem reset 6 days ago and changed nothing since then (except wifi SSID)
Denise van KPN
  • jan. 24, 2025 7:07 a.m. UTC
We'll just have to wait until an update sticks, then. Another reset of the modem might help, but still is no guarantee.
As for the loss of internet when connecting to tailscale: I honestly have no idea what this could be. Did you contact your IT support yet?
  • jan. 24, 2025 2:51 p.m. UTC
Yes I contacted IT support and we contacted Tailscale about it
Could you please provide details of 1st hop? `195-190-228-10.fixed.kpn.net`
Is it fiber box? Is it a single thing for floor/building/district?
  • jan. 24, 2025 3:30 p.m. UTC
This is your WAN IPv4 adres 195.190.228.10, i hoop that you wil not be a victim of DDOS attack in next days, because you put your own ip adres on a public forum.
  • jan. 26, 2025 11:38 p.m. UTC
No, it is not
  • jan. 27, 2025 6:06 a.m. UTC
No, it is not
What is your IP adres from site whatismyip.com
nslookup 195-190-228-10.fixed.kpn.net
Server:  security.cloudflare-dns.com
Address:  1.0.0.2
Non-authoritative answer:
Address:  195.190.228.10
  • jan. 27, 2025 7:23 a.m. UTC
No, it is not
Address:  1.0.0.2
Not 195.190.228.10
  • jan. 27, 2025 8:10 a.m. UTC
Not 195.190.228.10
Then it is the IP adres of the POP station in jouw neighborhood.
  • mrt. 16, 2025 2:13 p.m. UTC
Denise van KPN
  • mrt. 17, 2025 8:48 a.m. UTC
That's very good to hear, ​@krock21!
