Box 12 unable to connect with DHCP
  • jan 24, 2026 5:05 p.m. UTC
  • 84 keer bekeken
Devices only connecting with STATIC-IP and it's impossible to get connected while IP setting are in DHCP. I need to be able to connect with DHCP because otherwise all of my home devices cannot connect! Thank you for your immediate fix because it's important to have a doorbell and lights in the house that work!
Hi ​@Apo Z, welcome to our community. DHCP should work right out of the box. Did you change any settings?
We have written some articles about these features on the Box12
2 reacties
Thomas van KPN
  • jan 27, 2026 8:44 a.m. UTC
  • jan 27, 2026 10:17 a.m. UTC
Hello, I found some documentation and I fixed it. It worked for now, thanks
