Can some help with Cisco router configuration for KPN Fiber?
  • jul 14, 2022 6:18 p.m. UTC
  • 9 reacties
  • 889 keer bekeken
Melih
Nieuwkomer
Hello All,
I want to activate KPN fiber connection with my cisco router however I have an issue with pppoe.
Is there any one already configured it ?
interface GigabitEthernet0/1/0
 description KPN Internet access port
 switchport access vlan 100
 switchport mode access
 mac-address d06d.c9d9.c4a0  < this is the mac address of KPN modem WAN interface>
 speed 100
 duplex full
 no cdp enable
end
interface Vlan100
 description KPN Internet vlan SVI
 no ip address
 pppoe enable group global
 pppoe-client dial-pool-number 1
end
interface Dialer1
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip verify unicast reverse-path
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 dialer idle-timeout 0
 dialer-group 1
 no cdp enable
 ipv6 address autoconfig default
 ipv6 enable
 ipv6 verify unicast reverse-path
 ppp authentication pap callin
 ppp pap sent-username D0-6D-C9-D9-C4-a0@internet password ppp
 ppp ipcp dns request
 ppp ipcp mask request
 ppp ipcp address accept
 no ip virtual-reassembly
end
Beste antwoord door Anonymous
Thank you for your reply.
what is pap username and password?
You can fill in anything, so the example which they give is fine:
username: internet
password: internet
9 reacties
  • jul 14, 2022 8:57 p.m. UTC
Hello @Melih
I don't know anything about that router, but you should use VLAN 6.
Info below comes from the document Glasvezel Internet (PDF) from this page https://www.kpn.com/service/eigen-apparatuur.htm :
Technische details Internet
•  PPPoE via VLAN 6 (802.1q).
•  PPPoE authenticatie PAP met een gebruikersnaam en wachtwoord (bijv. internet / internet).
•  Maximale pakket grote (mtu) 1500 bytes (rfc4638)
•  IPv4 adres + DNS servers via PPPoE verkrijgen
•  IPv6 adresreeks + DNS servers (IPv6) via DHCPv6-PD verzoek (in PPPoE). Een adres gebruiken uit reeks voor router.
Melih
Nieuwkomer
  • jul 14, 2022 9:07 p.m. UTC
  • jul 14, 2022 9:08 p.m. UTC
@wjb kan jij mogelijk helpen jij bent de expert in eigen modems 😁
  • jul 14, 2022 9:11 p.m. UTC
username: internet
password: internet
Sanne van KPN
Hi @Melih and welcome to our forum! Did the tips from @GeSp help you with configuring the cisco router?
Ik vermoed dat die nog op vakantie is. 😫 Die hadden we hier inderdaad nog goed kunnen gebruiken.
Melih
Nieuwkomer
  • jul 16, 2022 5:41 p.m. UTC
Hello all,
it helped! Basically the issue was lack of dot1q tagging configuration on provider facing interface.
And other important thing is pppoe configuration should be done under subinterface not svi interface.
Thank you kpn community especially @GeSp
Melih
Sanne van KPN
Great! Thanks for letting us know. Then I'll mark the answer for this topic, but should you have any questions in the future don't hesitate to make a new topic! Thank you @GeSp! 💚
  • feb 28, 2023 7:06 p.m. UTC
Hi everyone,
This might be a old post. But I would like some help too with configuring a cisco router with my fiber to home connection.
Internet → FTU → Cisco 4221 → Cisco SW → Wifi and connected clients.
I have a working internet connection but the bandwidth is not what I am suppose to receive. I have a 200Mbps line and im reaching about 35Mbps. I am not sure what to do. Is there someone that can assist me?
  • feb 28, 2023 7:43 p.m. UTC
I think you should really consider to replace your 4221 by a router with a higher throughput.
