Connect printer to wireless network
  • aug 28, 2019 10:27 a.m. UTC
  • 117 keer bekeken
I am using Epson printer for last 1 year. My printer is showing Epson Printer Error 0xf1 after updating my device. If you have any useful ideas please help me with suitable
*afgesplitst en eigen topic voor je vraag aangemaakt
Hi Sophia, welcome on our board.
Do you mean after updating your printer? Or do you mean another device? I would try to simply install the drivers of the printer again after deleting it first, assuming there is no paper jam issue. Just type the series/model number on the Epson site for the newest drivers. I hope this helps.
Forum|alt.badge.img+28
  • aug 29, 2019 4:30 p.m. UTC
  • feb 21, 2020 12:02 p.m. UTC
My printer is not working correctly. I feel that it is due to the printer settings. How can I find out how they should be set. When I print a list of items, 1 page, it prints on the bottom of the first page the first line of the list and prints on the second page 1 item. Nothing printed on the in-between items on the list.??? looking for a printer repair, help.
  • feb 23, 2020 2:22 p.m. UTC
Hi N,
You should try a local repair shop or call the manufacturer. You do have a 2-year warranty on the printer. Printer repair usually isn't worth the time and money, printers nowadays are quite cheap. Depends on the printer of course.Â
