Disconnects due to thermostat
  • feb 23, 2021 7:54 a.m. UTC
  • 50 keer bekeken
Hello, i have the same issue.
I tried to reserve an IP for thermostat, change settings to use 802.11 b+g+n, however whenever my thermostat is connected to wifi it’s causing restart of experiabox 12.
If i turnoff thermostat, internet works stable
Reset of exepriabox and thermostat doesn’t help.
Any advise?
P.s. I don’t want to add extra router. And if doesn’t work i’ll consider to change the provider, unfortunately
Admin: eigen topic voor vraag aangemaakt
Beste antwoord door Egor
No, the issue started since the very begining of thermostat usage. So whenever thermostat is connected to experiabox with or without recommended settings, it cause restarts.
I found a workaround:
  1. i created a guest 5G network in experiabox settings
  2. i connected thermostat to that guest network exclusively, while other devices are connected to the main one
So far no issues and no restarts for 10+ hrs;
I see in the network stats that only in that guest network there are disrupted packets.
Egor
Hi @Egor, welcome to our forum. The restarting Experia Box is an odd result of connecting the thermostat. You said you've reserved an IP for it, and that it does this since then. What happens if you don't reserve an IP? Does the Box 12 still restart then? Or does the thermostat not work at all in that case?
  • feb 25, 2021 11:25 a.m. UTC
Egor
That sounds good Egor, I hope it stays working like this. If there is anything else we can do for you, don't hesitate to ask.
