How do I configure my Asus RT-AX59U to obtain IPV6?
  • April 23, 2025
  • 1 reactie
  • 162 keer bekeken
Hi All,
I need help with configuring IPv6 on my Asus RT-AX59U router. How can I set it up to obtain an IPv6 address from KPN?
Thank you in adavance
1 reactie
Jan van KPN
  • April 28, 2025
Hello ​@Sina1961 , thanks for your message and welcome to our Community :)
To be honest, I have no experience with this type of device so I used the internet to find a way for you to obtain an IPv6 address
KPN uses IPv6 Dual Stack with DHCPv6. You should configure it like this:
  1. Log in to your router at http://192.168..1.1 or via http://router.asus.com
  2. Go to Advanced Settings > IPv6.
  3. Set Connection Type to Native.
  4. Make sure DHCP-PD (Prefix Delegation) is enabled.
  5. Keep Router Advertisement and DHCPv6 Server enabled for your LAN.
  6. (Optional) Set custom IPv6 DNS servers like Google's:
    • 2001:4860:4860::8888
    • 2001:4860:4860::8844
  7. Save the settings and reboot the router.
After rebooting, your router should receive an IPv6 address and a prefix from KPN. You can check if everything works via https://test-ipv6.com. Will you let us know if this was helpful for you?
