How do I connect a Unifi Gateaway fiber to my Box 12?
  • apr 2, 2026 9:23 a.m. UTC
  • 58 keer bekeken
I would like to connect a Unifi Gateaway Fiber to my KPN Box 12 and have two question regarding the TV+Box and foreign channels.
  1. The LAN connection would be KPN Box 12 ---- Unifi Gateaway Fiber ----- Switch ------TV+Box. According to other posts I would need to use the IPTV skript? It does not work without a skript? But it would work with the skript?
  2. At the moment (also in the apps) some foreign channels are only available when I am in my home network. Do Apps/KPN still recognize the “home network” when a Unifi Gateaway is connected in between?
Thanks for your help!
HI ​@Martini85, welcome first of all on our community.
I have to admit that I don’t have any experience with the Unifi Gateway. But if I may think along with you, I would advise you to ask this question in the topic below about using your own router, there are many experienced users active there who alot about this.
Using your own router instead of the Experia Box | KPN Community
I hope you will able to sort it out quickly.
2 reacties
  • apr 2, 2026 9:34 a.m. UTC
Sorry, the topic title is wrong. Maybe a moderator can change it.
Forum|alt.badge.img+28
  • apr 3, 2026 7:32 p.m. UTC
