Mag box
  • nov 2, 2020 5:19 p.m. UTC
  • 102 keer bekeken
Hello, i am trying to watch my mag linux box via internet but is not working. Seems that you blocked the signal. Before with telfort it was working good.
if i connect the box to the kpn mobile phone like hotspot, it works. So it must be something with the settings of the router
thanks in advance for your help
Beste antwoord door Babylonia
This "Mag box”, from what I can find is a IPTV media player box.
Should be no problem connecting to internet.
But dependant which services you are trying to watch, maybe you have to change some settings??
(IPTV services from abroad ??)
Do you still have the same WAN IP address as for internet connection as before??
http://wanip.info/
2 reacties
Vikash van KPN
Hi @Crys. Welcome. How strange that it doesn't work. I don't know the Mag Box well enough to answer this. This is a public Forum. The strength of this is that there is a community that likes to think along about a solution. I hope someone else comes along who has an answer to this.
  • nov 10, 2020 9:32 a.m. UTC
http://wanip.info/
