My KPN Box 12 keeps losing connection
  • June 15, 2026
  • 22 reacties
  • 103 keer bekeken
Hello,
I keep losing connection on almost daily basis.
I have to restart my modem in order to get back online.
Today it happened 3 times.
It happens also when it’s not being used,  for instance i’m not at home, nobody is using it.. and suddenly it lose connection (i notice it since i cannot access my NAS server anymore).
KPN Box 12 - V12.C.25.08.16
The Internet LED is still on, as the others, WiFi is blinking until I restart the device.
This has been roughly going on for the past 4/5 months, but not being at home all the time it wasn’t really an issue (apart from not being able to access my NAS), but now i’m back for longer time and this really needs to be fixed.
Any help? it’s getting really annoying having to restart the modem evey time, there is something clearly not OK with my box, should i get a new one perhaps?
Beste antwoord door A_Durante
@Maja van KPN looks like he managed to fix the issue. it was more complicated than originally planned.
part of the problem was in the cable broken, but there was also issue down the street (that most probably caused the original issue with internet dropping).
22 reacties
  • June 16, 2026
@A_Durante The power adapter probably doesn't have enough power. Do you still have this problem when Wi-Fi is turned off? You can request a new power adapter via https://www.kpn.com/service/internet/adaptervervangen
  • June 16, 2026
@TDN thank you.
i’ve never tried turning Wi-Fi off, mostly 70% of the usage comes via lan, but i also have several devices going via Wi-Fi.
I’ll try ordering a new power adapter.
  • June 16, 2026
@TDN i went on the page, but it just asks to check my adapter via the first 4 digits.. and when i put those, it tells me that the adapter is OK and doesn’t let me order a new one
  • June 16, 2026
@A_Durante With Wi-Fi turned off, the router consumes approximately 2–3 watts less. If the power adapter can’t supply sufficient power, this check can confirm whether your power adapter is defective. If the online check doesn’t offer you the option to replace the power adapter, you’ll need to call customer service and explain that your router freezes when Wi-Fi is on but works fine without it.
  • June 16, 2026
@TDN i called customer service, they also checked the adapter and they think it is ok.
We did a modem reset for now, i’ll see if it holds up, else we’ll try something else.
Maja van KPN
Hi ​@A_Durante,
Did the modem reset fix the issue? Or is it still losing connection? If it's still losing connection, can you please test if it’s still happening with the wifi turned off? I understand that's rather inconvenient, but it will provide us with information about the status of the power adapter 🙂
  • June 18, 2026
Hi ​@Maja van KPN ,
for the time being it seems like it's holding up and it didn't lost connection once yet.
I'll keep monitoring how it goes these next days, and try to stress it a bit more too to see if it holds up.
Maja van KPN
Sounds positive ​@A_Durante, keep me posted!
  • June 18, 2026
@Maja van KPN looks like we spoke too soon.
it just lost connection, and i wasn't even at home using it. i came back now and there was no internet.
i'm going to disable the wifi now and see how it goes.
  • June 18, 2026
@Maja van KPN Hello again,
it just lost connection again also with wi-fi disabled 😫
Maja van KPN
I'm not sure that this isn't caused by the power adapter, so I did order a new one for you ​@A_Durante. It will be delivered within a few days. Will you let us know if things stabilize with the new power adapter?
  • June 19, 2026
@Maja van KPN  thank you.
not sure if things got even worse but today i had no internet at all, and now the glasfiber box is also not turning on. the "glas”light is off while the others are on.
tried to unplug all and wait a bit like we did the other day, but nothing is happening and there is just no internet coming in at all😫
  • June 20, 2026
@Maja van KPN
hello, i have received the new adapter and installed it, however as i mentioned in the previous post, there is just no internet coming in at all from the glassfiber box as you can see from the photo below.
i have already tried multiple times to power it off, wait the 2 mins, and power it on again, but nothing is happening. can we please sort this out? is getting really annoying by now..
  • June 20, 2026
Your fiber-optic connection is down. It's possible that the ONT isn't making proper contact with the FTU, or the problem is in the cable between the FTU and the neighborhood exchange. You can check your connection via https://www.kpn.com/service/internet/geen-internet and order a technician.
  • June 20, 2026
@TDN ​@Maja van KPN  the neighborhood seems ok, it's just me according to it:
i don't see an option to order a technician on that page. and not really keen on having to pay for it either, unless he can do it for free. this is not my issue, i haven't done anything. Anything else i can try on my own?
  • June 21, 2026
@A_Durante The neighborhood exchange does not seem OK. There is a red cross at the neighborhood exchange. You can order a technician via https://www.kpn.com/service/monteur (Repair)
Is the problem caused by KPN equipment? If so, a technician will visit you free of charge.
Is the problem not caused by KPN equipment? Even then, a technician will visit you starting at €99.
If website doesn't offer you the option to schedule a technician, there will be a "Call Us" button visible.
To make sure the problem isn't on your end, you can do the following: slide the fiber-optic box down, clean both green connectors with compressed air, and slide the ONT back onto the FTU.
  • June 21, 2026
@TDN  ok thanks for the link.
I was able to schedule a visit for tomorrow. let's see!
Maja van KPN
I see that your glass fiber has broken and needs to be welded, this afternoon. Will you let us know if everything is alright again after the mechanic has left ​@A_Durante? 🙂
  • June 23, 2026
Hello ​@Maja van KPN
yes the technician found the cable broken inside the box. I wonder if that's what caused the internet to drop before, perhaps making some false contact and now it eventually finally snapped for good.
anyway, i'll update once the other mechanic has worked on it later today.
Maja van KPN
My measurement system did not show a complete loss off connection in the days before it broke, but I do see many quick connection losses in a very short time frame right before you went offline completely. So it could be a coincidence, but of course it's also possible that it was caused by the process of breaking.
I'm hoping to read a positive update later today! 🤞🏼
  • June 23, 2026
Maja van KPN
Ah, I'm glad the mechanic got to the bottom of it and fixed everything ​@A_Durante! Thanks for the update 😊
