My own router WRT3200ACM
  • February 2, 2020
  • 1 reactie
  • 231 keer bekeken
Dear all.
Currently I am using the Experia box v10 but I want to replace it for Linksys WRT3200ACM. I want to use only the WRT3200ACM router and disable the experia box. I only have internet service and I don’t need VoIP or television. I have already tried to set up the new router (Linksys WRT3200ACM) but I have no  internet when I use this router. I am not sure if that is becuase I need the ISP username and password. I tried with different username and passwords including “kpn” or “ppp” but nothing worked.
Could you please help?
1 reactie
Paul van KPN
Forum|alt.badge.img+26
  • Oud-Moderator
  • February 5, 2020
Hello @Own router WRT3200ACM. You should read this topic: Use your own router instead of the Experia Box. You might need some Google Translate though.. :sweat_smile: Hope it helps!
